Demographics: tell us about your truck and your ambient conditions:
- Year: ____1994__
- Truck model and class (ie: c2500) ___3500______
- Automatic or Standard ______auto____
- Mileage: (indicate miles or km) _____161,000 miles____
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ____IP,PMD,OPS_______
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? _____"F" tubro, no EGR_________
- Ambient outside temp: (indicate *C or *F) ___trouble starts about 80-85deg f _______
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ___#2______
- What fuel additives are you using? ____power service_______
- Where are you located? _____MT________
General maintenance: inspect and evaluate the condition of each. When were they last changed?
- Air filter _____about 5000 mile ago____
- Fuel filter ____yes several times_____
- CDR Valve? _____HUH?____
- Coolant – last flushed/replaced at _______unknown______
- Oil – synthetic/regular, changed at ____regular 3000ish miles_______
- Batteries – state of charge, (matched set) replaced at _matched set fully charged replaced 2 years ago_______
- Battery cables and grounds (removed, cleaned and tightened): ____yes__________
- Glow Plugs - how many miles on them? ____unkown_____ What type? _____unknown________
- Injectors - last changed at _____unknown__________
History: (Describe how the problem first appeared.)
- What were you doing when it happened? ___driving about 30 MPH___________
- How was the truck running fine before this problem appeared? _____running good________
- Has this problem ever happened before? _________no______________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __Y__ And? ____17,18,35,36____
Diagnostics:
1] Starting:
1a] Does the engine start? _____yes____
1b] Does the engine crank over? ____yes____
1c] Are your batteries fully charged? ____yes_____
1d] Have you removed, cleaned, and tightened all battery connections? ____yes____
1e] Does your Wait to Start light come on for a time? How long? _________
1f] Does your glow plug light come on? _____yes____ For how long? __15-20 sec_______
1g] Do you see smoke from the exhaust while cranking? What color? ___no_____
1h] Does the Service Engine Light Glow during Start/bulb check? ___yes_____
2] Fuel Issues (if not running):
2a] Can you hear your lift pump working? ____yes________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _____yes____
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___yes________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? _______yes____
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _____behind bumper______
3b] Condition of Extension harness (if used) Vendor or Homemade? ___new vendor______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _____good____
3d] PMD Make: ____stanadyne_______
3e] PMD Age: ______1000 miles_______
4] Stalling Issues
4a] Do you experience stalling only when hot? _____yes_______
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ____anytime__
4c] Does pouring cool water over the IP seem to help with restarting? ____no_____
4d] Is stalling momentary (engine recovers)? _____no____
4e] Does SES light come on when engine hiccups? ___sometimes______
4f] Does cruise control quit working when engine hiccups? ___yes________
4g] Does re-starting seem to reset engine, restoring cruise and power? ____yes_____
4h] Changes to dash lights or instruments during stalling events? _____no______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? __no_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ___no_______
5d] Excessive white smoke from exhaust on cold start? ___no______
5e] Excessive black smoke from exhaust under hard acceleration? _____some but not alot_____
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ____no_______
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? ______no________
6d] Have you changed exhaust / downpipe / crossover? _____no___________
6e] Wastegate – mechanical or vacuum (OEM)? ________vacuum______
7] Temperature-related Issues:
7a] Single or dual thermostats? ______single______
7b] Have you replaced them lately? Manufacturer of replacements? _____no____
7c] Have you pulled and cleaned Radiator and coolers lately? ____no________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ____no____
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? _____no______
