ak diesel driver
6.5 driver
my 141 is not behind the head
One reason I love where I live. My 88 doesn't have rust anywhere, both doors are still completely solid.I might be selling a set of power doors from a 98. They have only a very small amount of rust on the bottom lip, but im trying to find a set of doors with ZERO rust. They might be good replacements for what you have now. If you are interested ill be sure to give you first dibs. Oh and they even come with pre-installed stainless steel west-coast mirrors![]()
I have a 3 year old GM bumper you could buy cheap from me if you need it. Chrome with the rub strip and the plastic bumper guards
Crap....I just put the order in with LMC a few days ago, so I should be seeing mine very soon. I may be interested for another truck though..where abouts are you located?
So I finnaly got some time to put up pictures of my most recent projects...starting to get busy at work, and I have to hurry up and finish as much as I can before I get kicked out of my temporary workshop
Got the seatcovers installed and I can say I am very happy with them. The color is a very close match and I think goes well with the rest of the interior. They even included covers for the center console/armrest, which i chose not to put on. The fit is very nice...only one complaint I have is that the cuttout for the power seat switches dosent line up that well. They also had a cuttout for power lumbar on the pass side, which these seats did not have. Overall very happy with the quality....and now with mud season here, they will be put into good use!
Now that I had the covers installed (much easier to do this out of the truck) I went ahead and bolted the seats in the truck...or well i had hoped on just bolting them in. Took out the uncomftorable and ugly blue bench seat (for sale I might add) and then scrubbed the entire floor with a cleaner and brush. Removed the sill plate and ran the electrical for the power seat. The seats I got came out of a tahoe in the junkyard and aparently they use a different mount then the pickups. Had to drill a few holes in the floor, but the biggest issue was the tahoe mounts put the drivers side seat much higher than the pass seat. I ended up cutting off the rear single mount and just using the front one for now. Also had to shim up the rear. Not exactally the greatest, but it will work for now untill I can find a set of truck mounts.
Same goes for a suburban seat. The mounts are way wrong for a regular cab pick-up. I'm not shure about extended cab trucks.
They bolt right up, all the grilles are designed for them actually. The only thing is you have to switch the connectors out.
I plan to put a set in the 99 with e-codes and HIDs as well.
