Hey, thanks for the welcome, I post on some of the other 6.5 sites around but I just recently came across this site and there seems to be a lot more enthusiasm here. When I first got my truck it was all stock and I soon learned the wonderful world of working on 6.5's. As you can see I've only done the basic mods and I am quite happy with the way that the truck runs. She just turned 2000000 a few months ago and I drive her every day, the only thing i don't care for is the 4.10 gears as I do mostly highway miles right now. But as for the clutch when I did it I bought it as a kit, clutch, pressure plate, bearing and flywheel. Since I put the clutch in a few years ago I really haven't talked much about it so I'll give some of my thoughts on it. Seeing that I was switching fom the DM to the SM setup the first thing I got was the vibration damper from a local shop and the price is a lot better than I could find on the web and had them install it, all total for that was around a $180. The first thing I noticed when I got the clutch was the lack of springs on the pressure plate they have these type of dampers instead and the other fact that it is stamped LUK. To be honest I wasn't very happy seeing that but.... So after the install which went nice and easy the other thing that I noticed is that the clutch now catches at the very top. Like I said with this clutch it is either engaged or not, there seems to be no middle ground on that for me but the clutch has been rock solid. I have had 3800 pounds of dirt on the back of her and she didn't miss a beat. I towed a full size car trailer with a 1968 Pontiac Lemans back from VT and I forgot It was behind me, so what I'm saying is this has been a pretty good clutch so far. The only other thing is the clutch is a little noisy when in neutral but not half as bad as the old duel mass was with all the broken springs it had.
Dan
