Thanks aceneights1,
But I think I read somewhere on GW famous thread that the entire setup with the Raptor, lines etc cost him a pretty penny.. We are planning on doing some pretty decent traveling with this Burb and reliability is my main concern. I did like with the Air Dog of having the filtration with the LP..
Famous? My thread?
Nah, I'm just a squirrel trying to get a nut.....
Personally, I think the airdog setup is too much for our trucks considering the benfit you would get for the cost, but it would also work great if you installed one. Just make sure it's adjustable, our trucks like somewhere around 10 psi at the inlet.
Plus, the filter choices and suppliers are much more limited than say, a racor, which can be had almost anywhere if your filter ever waxes up.
I've got about 700 bucks into my
whole system, from tank to injector pump.
Breakdown is something like this:
raptor kit - 400 bucks (included 16 feet of 1/2 push lok hose, fittings and some wiring)
FTB ver2.0 - roughly 100 bucks (walking J)
Prefilter - roughly 100 bucks (ebay snatch)
New stock filter - 50 bucks (stanadyne from a local shop)
Miscellaneous fittings, wiring and bits- 50-75 bucks
If you're worried about reliabilty and breaking down, here's what I would do:
Install a 10 micron prefilter, probably a racor due to ease of sourcing replacement filters. Then, I'd chuck a spare lift pump into the glove box just for good measure.
The advantages of this is that prefiltering fuel seems to (by others reports) extend the life of the lift pump several times over. By keeping the stock lift pump, if you break down swapping one in is a job anyone can do and parts are going to be much easier to get than say.....a raptor 100.
My system was built with a eye towards adding more performance in the future. If you're going for a reliable driver that's easy to fix, stay close to stock for ease of sourcing replacement parts nearly anywhere.
Well, stock-ish, except for a good prefilter that is....
One last note:
Raptors are no longer lifetime warranty. 1 year only now...:mad5:
Not sure what that means for those that bought before they switched to 1 year warranty........:???:
