Thanks for the relay schematics guys appreciate it if I can figure it out its kind of hard to read the fine print.
Well I started the truck up and opened the drain valve and the pump appears to be working. I filled a quart bottle up, I didn't time it but it seemed like it didn't take to long. I was going to check how many volts I had at the LP with the truck running, when I checked it pegged the meter ,I thought I had the meter on the wrong scale but before I could check again the truck ran out of fuel, it turned out it was on the right scale anyway.
Whats weird I crawled under the truck and put 12 volts to the LP and I could not make the pump run . Is this pump getting ready to go south on me?
On the rubber fuel lines I could not find one that looked like it was bad, the line going to the IP was a little loose so that might have been the problem. I'm going to put all new hose's on it anyway. Where the supply line hook's up to the IP does the nipple fitting seperate from the fitting with the screen or is that one piece? I tried to take it apart but I could not budge it, I didn't try to hard cause I didn't want to destroy it, thanks again.
Mark
