2000 bearing assembly & rotor to 1996 Suburban
The steering knuckle part number for the 98 is 18060568
Does anybody have a link to an application guide?
I hope that isn't the sites part number. I've been having trouble checking it.
What I found for application for the steering knuckle makes it appear the swap will work. The steering knuckle seems to span into year 2000 when they switched the hub to a floater as it should be.
Mechanical Catalog
Item Number MSRP Price
18060568 $674.36 $399.77
Front suspension - Suspension components - Knuckle
Knuckle, all, 4wd, over 7500 gvw, right - coil spring type 1991 - 2000
Add to Cart Contact Us
Knuckle, all models, 2500 series, right side, all - torsion bar type 1997 - 2000
Knuckle, all models, 1500 series, right side, diesel - torsion bar type 1997 - 2000
Knuckle, all models, 3500 series, right side - torsion bar type 1997 - 2000
Collision Catalog
Knuckle Right - 4wd 1 ton 1997 - 2000
Front suspension - Suspension components - Knuckle - Gvwr 8600
Gvwr 8600 Right - 4wd 3/4 ton 1996 - 2000
OEM Catalog
KNUCKLE
I was just talking to a guy from Centricparts.com that suggested that very thing.
86mm Centric caliper part number 141.66021 and 141.66022.
Could somebody cross those to AC or GM for me?
He also new about trying the 2000 HD bearing/hub assembly. The problem being with that is the lack of caliper clearance.
I'm kind of confused on how the parts match up.
It's hard to figure what parts work with what and why. Partly because the application page I used to use no longer comes up.
There is only about 1/8" clearance with our current rotors. Which are 12.5" diameter.
The Centric part number 12066042/ Wagner 126036 are about 12.8" diameter. They would crash. I checked Centric because that is the brand that came up with a part number on my search. The sizes should be good for reference.
Matt, what is the outside diameter of your 3500 rotors. I'm guessing 12.5" Let us know.
Would it be possible to order floating rotors from someplace turned 1/8" smaller diameter? Do Frozen rotors manufacture their own? Might they do customs?
Does anybody have crossable numbers for these rotors to AC, GM or another popular brand?
I don't think offset should be an issue, but i have not thoroughly investigated that yet.
No future unless I can find a working rotor/caliper combo.
By the looks of the specs I do not think offset would be an issue.
An email I got from http://MIBearings.com :
Hello,
I have attached two files for specifications on the hubs that fit the 2000 GMC and the 1998 GMC.
Please see http://mibearings.com/HUB_ASSEMBLY_DIAGRAMS.html for diagrams that will help expain the specifications.
I have also attached images of the hubs below
Please let me know if these will work for you.
Don't hesitate to contact me with any questions or comments.
Thanks,
Luke Rehmann
MIBearings LLC
US Toll Free: 877-929-7280
Int. +1 231-929-7280
http://www.CVAxles.net
http://www.CorvetteWheelBearings.com
Full line of Engine and Undercar Parts.
2000 GMC 3/4 Ton Hub Assembly Specifications
Description Value
ABS/Non-ABS Y
Bearing Type Tapered
Bolt Circle Diameter B (in.) 6.500
Bolt Circle Diameter B (in.) 165.1
Bolt Circle Diameter H (in.) 140.00
Bolt Circle Diameter H (in.) 5.512
Bolt Quantity Size I (in.) M14X1.5
Bolt Quantity Size I (in.) (4)
Brake Pilot Dia E (in.) 117.89
Brake Pilot Dia E (in.) 4.641
Driven - Non Driven D
Flange Diameter A (in.) 7.846
Flange Diameter A (in.) 199.30
Flange Offset F (in.) 58.35
Flange Offset F (in.) 2.297
Flange Shape J Modified
Flange Shape J Square
Gen Type 3
Hub Pilot Dia G (in.) 4.167
Hub Pilot Dia G (in.) 105.84
Lug Bolts (Y/N) Y
Roll Form Y
Spline Quantity 33
Stud Quantity Size (in.) M14X1.5
Stud Quantity Size (in.) (8)
Tone Ring / # Teeth -
Tone Ring / Sensor / Encoder S
Tone Ring Dia. -
Truck Y
Wheel Pilot Dia D (mm) 116.69
1998 GMC 3/4 Subrurban
Description Value
ABS/Non-ABS Y
Bolt Circle Diameter H (in.) -
Bolt Quantity Size I (in.) M14x1.5
Brake Pilot Dia E (in.) -
Flange Diameter A (in.) 8.19
Flange Diameter A (in.) 208.026
Flange Offset F (in.) 68.326
Flange Offset F (in.) 2.69
Flange Shape J Rectangle
Gen Type 2
Hub Pilot Dia G (in.) 4.165
Hub Pilot Dia G (in.) 105.791
Lug Bolts (Y/N) N
Roll Form N
Spline Quantity 33
Stud Quantity Size (in.) 0.6
Stud Quantity Size (in.) 15.24(8)
Tone Ring Dia. -
Truck Y
Wheel Pilot Dia D (mm) 116.586
2.69
Flange Offset F (mm)
68.326
Flange Shape J
Rectangle
4.165
Hub Pilot Dia G (mm)
105.791
Spline Quantity
33
116.586
Tone Ring Dia.
S
Tone Ring / # Teeth
It looks as of the thicknesses are to far off.
The hat sizes not shown are out of tolerance. The maximum for our pads to fit would be about 8 1/4" the rotor shown is over 8.5 inches.
It would take a custom caliper.
Maybe SSBC? It's worth a call.
How did this project turn out?
Since we know the steering knuckle is the same from 99 - 2000, why couldn't you use a 2000 hub, caliper and rotor? That should keep everything within spec.
I would think you should be able to.
Part of the problem is I haven't checked to see if there are other steering knuckles used in the same application.
Somebody needs to go through and check all the part numbers to make sure they'll work. I ran out of time and went back to the stupid rotor behind
