bison
nope, just take it out,note the position of the baffle(has to point down with hole behind it after install) and screw it back in.That has to be it!
My wife is into Geocaching where you find hidden caches using a handheld GPS. It's like a treasure hunt. I oblige her in this activity on our road trips. I call her GCQ or Geocache Queen.
This geocaching has me frequently exiting the highway and going offroad. There was one instance where I forgot to pull it out of 4wd Hi after re-entering the highway. I discovered this oversight a couple miles later. Wouldn't be the first and won't be the last time this happens. The original post in the thread said the vent tube blows oil if he goes above 40 mph in 4wd. Well I was on the highway, so I know I exceeded that.
This on top of the new CDRSo I guess I need this plastic GM Part # 12479390.
, idler pulley, interior hood pull handle, etc. Never ends. Maybe once I get through all this stuff, I can finally get the Heath Cooling upgrade, then the ATT Turbo and Kojo Chip? Then I'll be styling.
Oh, the check engine light just came on in the Honda Accord. It says check the fuel tank cap, or take it in to the dealer as it's probably some emission equipment that failed at 52K miles. Just what I need as I'm in the middle of going through injectors on the boat diesel. Never ends.
Steve
Clean and test your CDR before buying new.
