matuva
Tropical 6.5er
Well, I found several post about cooling system.
It appears GM forgot to put a simple tap on block which should have allow us to completely empty and clean the block.
Though, I may have to check close engine mounts, it seems i saw a plug somewhere.
I will have to flush completely a 1995 to get rid of the Dex-crap and replace it by green coolant.
I want to clean it as well as possible so that no Dex-crap could mix with the green.
This 1995 is a single stat mount.
What I'm willing to do is to :
Do you think that should be considered as a good way of doing things ?
- wait till the engine is cold or just warm;
 - remove the T-stat;
 - connect a garden hose at the upper rad hose;
 - open wide tap and run/idle the engine till clear water comes out of T-stat housing;
 - stop engine;
 - pull the lower hose to flush the rad and part of the engine;
 - put back T-stat and hoses and refill/bleed the system.
