FSD/PMD "Points to Ponder" How hot does it get
Turbine Doc
Just Another Diesel Guy
Gautier, Ms./Anywhere Southern USA
I posted this study back at old site, if you go there look in FAQ PMD info; only posting my musings as I don't own the opinions of others offered back then, so will just post my direct observations:
6-26-04 I have a little experiment I have been thinking on, that I finally got around to doing with the infamous FSD, maybe old ground already covered maybe not.
In Jan 04 I had a FSD "go bad", shut me down on the highway on a return trip from my hunting camp about 2 hours into the 2.5 hr return trip, outside temp was 50F, FSD mounted on a cooler was cool to the touch but would not let the truck start, it had stumbled a couple of times before shutting down, 1 restart then no start. At the time that FSD had about 50K on it, swapped to the new spare I carry and came home. New spare has about 10 K mi on it.
I got home and cleaned up the Bad FSDs transistor mount studs , nuts, to remove any oxidation that might be present, and re-torqued to 10" lb, I slaved it in and truck started right up, it became my spare.
With all the debate it's heat, its loose fasteners, I decided to run an experiment but did not get to it today. Bad FSD reinstalled at 84200, now at 84212mi no problems, will long road test tomorrow.
I took "bad" FSD and; reinstalled it on the cooler, but I 1st filed a small groove in it's base to accommodate a thermocouple wire that touches one of the transistor bases just to see how hot these things actually get and how long will this "bad" one hang in there.
My cooler is mounted on drivers side fender in pocket/bracket where a gassers washer fluid tank goes.
My engine was warm I had been road testing brakes after installing new stainless braided brake lines, I had run it for about 15 minutes. I only have 1 thermocouple so I don't know under-hood temp, ambient air was 80 F.
1st run was 15 minutes with engine at idle, hood down FSD at 96F starting went to 144.8 F in 15 minutes
I shut down the engine for 25 min and temp had dropped to 119.3
I restarted engine and drove for 10 min city traffic 0-50 mph temp varied 135-139
Shut down for another 6 min temp went to 131, restarted and within 4 min 40 sec temp rose to 151.6
Shut down engine after 6 min of driving 0-50 and engine was 150.7
After 42 minutes FSD had cooled to 129.3
After 2 hr 10 minutes FSD was 116 deg
Truck restarted FSD 7min 45 sec 116F up to 133 F 0-50 driving approx 2 miles
shutdown for evening FSD after 30 min back to 118
Will collect more data in AM, I'll also be collecting some numbers on IP PMD location later
Okay I made a run yesterday 6-27-04 to my hunting camp I collected some interesting data. Basically the truck ran for 8 hrs start and stop hi way and woods crawling in 4wd . (Edit transistor after overnight was 100F)
I have 2 latest gen FSDs (34583s) the "resurrected one" as of yesterday had 343 mi on it, I put another 70 miles on it today so I'm up to 413 since retorqueing transistor nuts. Yesterday it was 88F outside today 91. Engine max temp was 192F and fuel temp was 140-144F
With temp probe in transistor cavity, and FSD cool plate mounted on driver side fender as before test I recorded following data:
After 85 minutes of driving temp at hi-way speed 70-75 transistor 135- 150, I shut off truck temp dropped to 147 after 7 min shutdown I restarted the truck after 3 minutes temp peaked up to 170.
Temp gradually reduced after 8 minutes back to 151 and varied 138-150 depending on speed for remainder of the trip 0-75mph about an additional 1.5 hr. total of about 2.5 hr of heated engine/FSD.
Once at the camp I had to shift to 4H gear crawled thru woods, stopping here and there to clear old dead falls across the road, the truck was left idling during time to clear falls, about 30 minutes on camp road I arrived at my cabin, 0-10 mph driving FSD temp was 213.5 and slow rising .1 deg every 3 sec when I shutdown.
I popped the hood to get some surface temps, after removing temp probe from FSD cavity the cool plate surface/fins was 185F 4 min after shutdown, temp on intake manifold was 178F after 10 min FSD plate was same.
I restarted the truck about 1 hr later for return trip this time with temp probe on intake at hi-way speed 70-75; intake temp was 187 within 15 minutes, FSD Plate/fins very cool 108-113 F, engine compartment at hi-way speed 160F just above engine aft of IP.
I relocated temp probe to base of the inactive PMD still installed there, (I have 2 spares 1 in glove box and 2nd like new on IP). temp at it's base at hi-way speed within 7 minutes went 153F to 169 F following the shut down to change location, I ran for another 40 minutes with probe here.
I then stopped with engine idling then slow drive for 2 miles @ 30 mph max IP/PMD was 165, FSD cooler surface temp was 138F
Initial conclusions from this are the FSD cooler does reduce transistor temp, with good airflow FSD even cool to touch. Further away from engine is better, probably outside engine bay is best. Right now I only have 1 set of transistor cavity readings, to nail this down some more I'll move the cool plate to the intake manifold and run same test with temp probe in transistor cavity.
Then I might move to the IP but it's such a PITA to get the PMD swapped over, last test I'll run is on a long extension into the cab to see if harness length is a contributor. I might also get a second temp probe from Sears so I can make better comparison without "skewing" result from frequent hood openings.
I think as we have found in past 2 fail modes at work heat itself 213 + on a transistor is darn hot, and loosening of mounting from heat/cool contraction/expansion reducing "clamping force" and giving poor ground to transistor base.
stay tuned folks more to follow.
8-4-2004 Update,
1325 mi and still going, put to ultimate test weekend before last, as hot under the hood as I've seen since I've owned this truck.
Towing my backhoe home from camp est. 18K towed weight 6K GN trailer, 12K backhoe; 101F 100% humidity MS day 50 mi short of 170 mi trip lower IC hose popped off for 2nd time that day just prior to cresting top of huge bridge(not sure of the incline at least 6 deg grade) I-65 South just 20 mi North of Mobile AL. "Dolly Parton" bridge to some, because of 2 side by side humps you get the idea.
Went from 45mph to 10 mph nearly instantly like loosing half an engine without any turbo boost, fortunately I had enough fwd momentum to make it over the top.
After getting arms burnt 1st time I fixed it that day I decided no more big hills left I'd finish drive home without turbo, I did not have temp probe with me but it was so hot under hood nothing could be touched for long, burns on arm still have light scab coming off.
Major Wrong decision to limp home that way, while I had no long hills left, I did have many little ones with long pulls in them; ever try to pull 18K stopped with basically 1/2 an engine; it ain't purty, once rolling I was able to hang in about 40-50 mph.
Getting rolling or climbing grade was hard part 5-10 mph and a long string of P/O-ed folks behind me, fortunately I was on back farm roads at the time this was happening folks sort of used to it.
H20 was getting hot up to 225F, trans fluid in pan was 200, EGT was 900 post turbo, IAT 250. when on the throttle hard making plenty of black smoke, I looked like one of those tractor pulling sleds(Guess I was one sort of).
I made the rest of the trip home windows down, heater on max hot to pull off some heat, and when buddy following radioed "heavy black smoke" backed off throttle, no sense in wasting the fuel it weren't doing no good making smoke.
All in all I survived, but at the end of the trip I was wrung out. Without the mods in my sig I doubt it would have been possible, the 83mm in Heath reflash I saw on the scanner makes heaps of black smoke without the turbo assisting.
Someone in another thread asked how tight to torque the FSD transistor nuts, using a quality in lb torque wrench and progressive torque I torqued to 10 in lb, I used progressive torque 2-4-6-8-10 in lbs as material under transistor is somewhat compressable, so rather than load up one side stage torqued, so far so good.
Will keep posted as time goes on.
In response to a reply made later that day offering condolences to my troubles and suggesting PC cooling fans as a solution:
Nuthin I could not handle, just one of those things that happen, partly my fault, I went cheap on the clamps, t-bolt clamps IMO only way to go everything else is second best. Especially if you plan on running at elevated boost levels, I was peaking 12-13 psi.
As far as fans go; yes they would help, but blowing hot engine compartment air across them will only produce limited result but better than no flow when stopped or crawling along going slow.
I'm thinking of a Heath bumper mount kit, or toying with idea cutting a hole in the fender and having heat sink fins protrude into wheel well area (Triggerman's Idea over at TDP). I'm on the fence about locating in the cab under the AC duct what if AC is broke or it's too cold, hot transistor and cold air may not be a good idea.
Better maybe to use outside air which be closer to transistor operating temp but still enough delta to transfer heat. It's been a while since I looked at my thermodynamics notes from turbine school so I might have it all wrong here, but from my Navy days on water to steam, oil, & bleed air heat exchangers if we put too much cold water in the coolers we actually overtemped and hammered/cold shocked the condenser.
Can we cool the heat sink too much and actually reduce a heat sinks capability to dissipate heat, I don't know just thinking out loud, from my discussions with Bill Heath his results show that cab mounted FSD were not as long lived as his bumper mounted ones maybe this is why.
Another possibility since we now have found that loose transistor mount screws can be a contributor in sporadic FSD operation, maybe as a result of large temps swings that would come from cold AC air vs cooler ambient air may be exercising and loosening fasteners over time. Also what about condensation causing connection contact point oxidation, as nuts try to maintain bonding plane especially in location as MS with 60+% humidity year round.
I think there are several fail modes for the FSD no one fix addresses all, and depending where you live may also impact results. Heat #1 problem, loose fasteners #2, combined heat and loose over time #3, faulty/weak transistor # 4, corrosion/gnd plane problems#5 order of occurance a guess on my part from reading posts here and TDP over the years.
And reply to another question on 8-6-04 about sealing of a remoted FSD
With the right sealing compound risk of water intrusion should be minimal, Bill Heath says he ran his submerged in water for a while just to prove to himself his would work (he is using a proprietary compound though).
I'd try maybe in bumper holes fins in air stream, FSD mounted opposite from air side, verify proper torque on transistor nuts and FSD to cooler screws, then seal seam at joint between the 2 with hi-temp rtv, GE type 106 red is a good one we use to hold turbine compressor shrouds in place, Permatex red looks to be very close to that, be sure bonding surface is oil free before applying it.
It gave up finally after 3x "resurrections" under hood, gave up on it 10-11-04 been running incident free with the Heath relocated FSD/PMD, have a 2nd Heath relocator on my burb been there since 2006 was 1st mod on the burb same great reliability.
This to me is just more proof that the PMD/FSD needs to be mounted on a heat sink out of the engine bay. Also makes me glad I do not have to deal with this headache on my truck.
This was one of the first thread in the other forum that I read when I just got my 6.5 Burb. It was a proof for me beyond a reasonable doubt about putting PMD outside the engine compartment. I hope it is linked in the Technical Library.
I got 2 dead FSD's(2 brandnew stanadynes.Before that the old relocated one had been on the intake for 2 yrs ) in 3 months on the 95 last winter,FSD is still mounted on the intake.never mind that, cause the underhood temps never went beyond
+ 20 celsius on the warmest day and the FSD likewise,that was 1/2 hr after shutdown.With engine running the FSD was only 12-13 degree C. I tested it many times,and temps were pretty similair.
ambient temp where between -15c to - 40c the entire winter.
Heat certainly was not the culprit on these 2 buggers.Got a Dtech on there now since early march.
I waiting for 3 months allready on the warranty claim.
Since I ran this original test I did some more R&D or had it demonstrated to me on test stand when visiting a IP shop in Florida I used to frequent every so often , that much heat self generated by the driver itself, pointing a IR gun at center of driver between the 2 transistors, about where chip itself resides on the board burried in epoxy, got 200+F within minute of free hanging in air on test stand, and driver begins smoking soon after that. I'm thinking cumulative heat cycles "do them in" as part of fail mode.
There was some internal discussion or so I was told by reputable "guy that knows a guy" formerly of Stanadyne telling how Stanadyne did not want to locate the driver on IP; because it would be "at risk" there, but GM did not want to relocate off the IP.
Which is sort of backed up by redesign/reprogram in 96+ to have dual power to lift via OPS & PCM so both have to be lost for lift to stop, as effort IMO to keep fuel supply constant which is indirect cooling medium for heat xfer for a IP mounted driver.
Also IMO if GM/Stanadyne "fessed up" to this it would open them to much more expensive recall campaign, than the replace upon attrition method the "special policy" 0064 @ 120K/11yr if it survived that long allowed for.
Now that most of those have been through the wringer, what an opportune time to come out with "new & improved" driver for sale to "fix" a problem that GM & Stanadyne for years denied was happening when they were on the hook to replace them.
great info and i guess i should take out the money one of these days and relocate my pmd
Thanks, highly recommend geting a remoted driver out of engine bay setup ASAP; it was my 1st mod on the burb as I said; I wish I had known about the Heath solution when I bought my 1st 6.5 in 2000, but then I maybe would not have made observations I did. Beta/DSG/Kennedy underhood solution wasn't a permanent fix for me.
I'm not a tron guy by any means, will soon have a piece of paper that says I'm now legal to discuss it though after nearly 30 years of dealing with them, finally finishing my degree.
Trained as a turbine mechanic and some basic electricity/controls in USN mostly mechanical but a LOT of troubleshooting ill effects from bad trons multiple times in many different tron control systems in turbines & Diesels, some common elements when they go bad, heat rejection is one of those common elements.
Also many an hour on phone from field to tron "experts" saying with 100% certainty "that can't happen" trons don't work that way, well it can and does happen, not supposed to on paper, or in a design lab, stuff happens in the field though, that just defies conventional tron wisdom.
well i know this problem already happened to the previous owner of this truck because he replaced the IP at 105000 miles which seems a little early for IP failure. and i also know for a fact he towed because of the trailer brake controller i have and he put a heavy duty reese recceiver so im sure it got hot after a lot of towing.
One of the question, If the PMD fails, will it make the IP lifecycle shorter?
With that much heat being generated itself, it should be passed on the IP also.
Compound that with the less lubricity ULS Diesel, I can imagine it makes the IP hotter.
Any thought?
Any thought?
Tough to prove. Defanately can only help the IP to get that heater off its back though.
TD, do you remember the article where the mechanic actually graphed the PMD's signals, and was technically able to compare the BAD PMD to the GOOD PMD, and actually diagnose the PMD instead of just replace it and see if it works method?
I was trying to find the link the other day, and coulnd't find it.
If I recall it may have been you that E-MAiled the guy to join us on the forums??
Was a great read. And wanted to re-read it myself, as well as find it for others to read, and re-read.
The IP is not affected by the small electronic thermal load of the PMD\FSD - while the engine is running the flowing fuel keeps temps copasetic at ~129-135*F, even with ac burning - internal fuel temps are same with PMD attached or FSD remotely-mounted, while engine bay temps range from ~150*F while rolling to ~300*F shortly after engine shut-down, due to EGT radiation from exhaust manifolds and turbo - it is only after engine shut-down that FSD temps will spike into the danger zone - those elevated temps seldom damage FSD components while in the 'off' state, but the wide temperature swings do wreak mechanical havoc to those components soldered to the pcb as the potting expands and contracts - this is the dreaded "heat-soak" damage referred to by experienced 6.5 folks but not found in the field service manual - this is where several vendors and self-proclaimed "expurts" go very wrong by recommending the FSD be placed on a heat-sink bolted to the intake manifold, barely 10" from the oem location: heat rises - the FSD\sink will absorb that increased heat most anywhere in the engine compartment, and most FSD's will eventually succumb due to mechanical heat-soak failure - a large sink\FSD module, water-proofed and externally mounted, is the only proven solution, as substantiated by one vendor's 7yr warranty, having sold that exact configuration for over 14 years - and the required ~72" extension cable has no detrimental effect on driver function - proven, but once again: not found in the FSM - but, no, IP function is not degraded by the attached PMD
GMCTD, well put. Glad to see your input here.
In all the testing we did the temps for a pmd/heat sink combo, bumper mounted the temps rarely got 20 degree over ambient.
I did the same test, not scientifically. Leroy is correct, never more than 20 degree over ambient. We measure that in Texas. The nice thing about TX though, our temperature fluctuation is not as bad as up north.
So youre saying the FSD gets hotter after shutdown from "heat soak"?
Seems contrary to the data on the first part of this thread.
So it would seem. Though the OP measurements are a varied intervals, 6 minutes, 25, 30 minutes, 42 mins and 2 hours, the temp (in every case) always went down, not sure there is sufficient data in this test to prove much of anything, except that the temp appears to always go down, but again nowhere near enough data to conclude anything at all, and points, that you can ponder.
I have my PMD on the IP, and it is cool (near ambient) to the touch (no scientific data, not worried about PMD failure) regardless of time engine is off.
HOWEVER: this is a problem ever since day 1 of the DS-4 and PMD, so (even though I have a D-tech) I have followed conventional wisdom, and keeping the heat soak "theory" in mind, have tried to eliminate, as well.
Keep the fuel tank as full as you can, since lower fuel levels will result in more heated fuel being returned to the IP, on a highway trip though, not much to worry about, lots of airwash over the fuel tank.
And I pop the hood when I get there and prop it with a PS bottle. Not always possible if you drive to shopping malls and such I suppose, but I drive to bird hunting territory or over the ice on a frozen lake to fishing spots, so not a concern to me.
Too bad the OP didn't test a PMD on the IP.
Well, one thing is you cannot measure with the hood close. So, we can only measure a downward trending temp instead of the peak.
