Replacement blower motor quality
SnowDrift
Ultra Conservative. ULTRA!
Central Ohio map dot
In the past, I had learned that when replacing a blower motor, the only blower motor to use is an OEM part and I made it a rule because aftermarket simply didn't make a quality blower motor. They were either noisy during operation, they vibrated or the fins were brittle and easily broke apart. The one in my little truck needs replaced - tweets at me when it's cold and gets noticeably louder when making left turns.
Is there a quality aftermarket solution or so or is it still an OEM only part.
