dbrannon79
I'm getting there!
Hello again, I got myself into more work for the next few weeks. My daughters father n law and very good friend's burb now sits in my back yard. we just got the fuel pump replaced and towed to my house. It's issue is after running for a while, it will suddenly just loose all oil pressure until it sits and cools off. It doesn't over heat or anything, drives fine, even the 4x4 works. It's a 2001 Chevrolet Burb with a 5.3l vortec and a 4l60E 4x4. as far as I know it's a 1500 or 1/2 ton but had 6 lug wheels.
I have read and heard others talk about the infamous 0.50 cent o-ring on the oil pump pickup tube cracking and loosing it's prime. not sure if this is the case but it has been verified loosing oil pressure since when the gauge goes from around 40 psi to 0 the lifters start clattering. I'm hoping that I will be able to drop the oil pan without pulling the engine since it's a 4x4 but I guess I will find out. I told him that it would be best to just pull it all down and replace the oil pump, timing chain, water pump and all going into it. any pointers, tips, tricks, or opinions? any input will be helpful.
![IMG_4448.jpg IMG_4448.jpg](https://www.thetruckstop.us/forum/data/attachments/71/71497-43ebbfe2779aef19924a807902f1be03.jpg)
![IMG_4450.jpg IMG_4450.jpg](https://www.thetruckstop.us/forum/data/attachments/71/71499-ddb5ff876cb5d08cde5e5bf8219ab3b1.jpg)
![IMG_4449.jpg IMG_4449.jpg](https://www.thetruckstop.us/forum/data/attachments/71/71498-11ea730fb9e46bf825b082e0d242230d.jpg)
