FYI coated radiators
Twisted Steel Performance
Pauline, SC
Unfortunately my coating material cost have gone way up, so coated radiators will go up 50.00$ to 500.00$ as of 10/1/2020.
Most other coatings are also going to be more as well, this is all due to all supplier products going up..
I think it would be interesting to have a temperature sender port near the lower radiator hose.
A person knows what the approximate coolant temp is within the engine, but, how about before the coolant gets sucked back into the engine ? LOL
i dont need a cap. the stock style is really wide but i think some of the truck units are even wider. my chassis is configured for a 95 g30 radiator. and it pretty much goes headlight to headlight in my ranger. but i have been thinking of reworking some things and a 27-30 in overall width radiator might make it easier if i stay on front leafs..
do you have access to the gear to gear timing set for the 6.x diesels? i was thinking of getting a banks 351 manifold and fresh drivers side oem manifold and getting it coated and running an hx 40. with that in mind making the radiator smaller is a horrible idea but i am not towing regular either.
that and a 6l80 would probably make me happy for a good 10 years...
