2006 Power Steering Hose Change
RI Chevy Silveradoman
At your service
Staff member
Lead Moderator
Rhode Island
I noticed that my original 2006 power steering hoses were leaking last winter. They only seemed to leak when it was very cold out. I checked the hoses and they appeared to be leaking a bit where the metal lines met the crimp on the rubber hoses.
SO I figured I'd get the jump on those this year. Lol
Anything specific or special I need to know on changing these out? Any special tools? Tips? Help? Guidance? Lol
@Rockabillyrat
Is it safe to just remove the lines? I read that there is pressure that may be in the lines.
Any help on which order to remove and replace?
And do I have to use a VAC tool to pull the air out and bleed the lines from the pump cap?
