matuva
Tropical 6.5er
That's what I bet by looking at that piston : the head of the piston is completely worn. So worn that the piston finally broke.
Is that that kind of damage we meet with worn injectors ?
This # 8 piston on a 929 block (1994?) found in a 1998 rig
Of course, it has to be changed. It seems it can be done "by under", after taking out the oil pan.
Any has already done that ? Do we have to pull the engine or not ?
I will check closer tomorrow, but I do believe it can be done with hte engine inside, but I'm not sure it will be an easy task....
Any idea ?
Any idea ?
