Danish Farmer
From reading posts in here I understand that the headlight relay is to be found on the grey under dash panel to the left of the brake pedal.:thumbsup:
Well.. My truck does not have one, :hihi: only a retrofitted drivers light relay is found dangling down there, getting its power-signal from a plug in the grey panel- and the rest of its wires seems to be coming from the ignition area and light switch area too.
Question: My driver lights work perfect and comes on when key is on, but now my normal head-lights (step two on the light switch) stopped working. Only parking light and dash light comes on when i turn the switch.
I hear no click any where, and the big red fuse in the engine fuse compartment saying (Lights) is good. Cleaned it with no luck.
The small fuses on the left side of the dash are all ok too.
Where could the strange relay be ? (Former owner did the driver lights relay)
Regards, the gye with a dark invisible dashboard![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
