wobbly damper
Jagerbom
My 6.2 chevy diesel developed a wobbly crank pully. By close investigation I found that it is not the pulley or the harmonic ballenser What could it be?
broken crank??? there's no slop in the balancer or pulley at all?? Truck run any different/?
when you checked the dampener, did you check the condition of the rubber itself? the dampener id mad of 2 pieces of steel with a rubber core.
