wiring issues HELP!!!!
TexasDan
Houston Texas
Guys, I've got a project where I'm installing a 94 GMC 6.5L TD into a Hummer Replica that I've been working on for years. I got the complete wiring harness for the engine and the computer. I'm very confused about what goes where. I know what connects to the computer and throttle pedal. If you go to www.ltw.net/photo1.JPG you can see the red circles around connections. It's the big connection in the back ground that I can't figure out. Is there a wiring diagram for this that is more visual than a diagram. if you go to www.ltw.net/photo2.JPG you see more red circles. I have no idea as to what these connect to.
Can anyone help Please!!
If you want to be cheap go down to the public library and look in the back of a repair manual for the year model of the wiring harness.
Once you find it go off connectors to wire colors till you find what you want.
or
Go to a wrecking yard with your camera and start snapping a lot of pictures.
Too me it is really hard to tell what goes to what without a wiring diagram and pictures with the color of the wires showing.
Wish you luck! :thumbsup:
