Wiper Delay switch
Patrick@HPD
Steel City!
On my 05 Cummins the delay switch for the wipers are screwed up. Twist the knob and they work. Turn them off and on again, and they may or may not. Once your past the delay the regular slow and high works fine always. Anything obvious that could be wrong? Probably need to take it in for a new switch. Wonder if it could just be dirty? Anyone else have this problem?
The switch is probably fine... there's a 99.7% chance it's the wiper control module. You'll have to take the plastic cowling off to reach the wiper motor. Unplug the connector, take out three torx screws and remove the black plastic cover. The circuit board that the connector plugs into is what gets replaced. $40 from most parts stores will fix your problem.
Hmmm....I just happen to be a part store lol. I'll have to check my server and see if I have a line on those. Thanks! Why do they continue to makes things so complicated? Whats wrong with the old way.
Man, I'm retarded... I just paid more attention and realized I may have given you bum advice. Well, if you had a GM product it wouldn't have been bum advice, but none the less I do sincerely apologize! :eek:
