Winter Starting Cure
any word on a kit for the 01-04 LB7 Duramax?...I use Marine batteries that could use a cable end that would fit over the screw with wing nuts...
Yes, I have a donor Duramax that I can copy its a 04, is the lb7 different than the lly battery wise? Ill be doing it the first of next week should be ready to seel a set the end of next week
Is your 04' donor a vin 1 (LB7) or Vin 2 (LLY)
Battery cable wise...I'm guessing they are are the same, but cannot guarantee it...
I'd be up for a set...
will the set go all the way to the starter?
and could you put an end that would screw/fit to a marine post (optima Blue top)?
Yes it will be complete starter, Alt, Power feed and grounds and sure I can make it with ring terminals for the Marine post, are they 3/8"?
Im not sure of the price until I get done but if the lenghts are not much more than the 6.5s It shouldnt be over 250 bucks, Friggin Copper prices are a bear but im getting a good buy on the 2/0 SGX cable so I should be good to go, Ill keep you posted
So did you finish the Dmax kit for Jcool yet?
Bruce I believe there was one other member that was chompin' at the bit to be second in line and lays his truck up for the winter...
