96GMC7.4l/454
- Messages
- 18
- Reaction score
- 54
Hey newb here just registered…
I have a 96 GMC C2500 suburban. There were two of the 3/4 ton made from my understanding. The light one has a GVW of 7800lbs and the heavy has a GVW of 8600lbs. Mine is the heavy and unless I’ve been misinformed only trucks over 8000lbs came with the good stuff. My truck or burban whatever has the 4L80E trans and a 14 bolt full float rear end driven by a 7.4L 454. My question is can the 4L80E trans shudder at highway speeds. I’ve had a shudder and can not find the source. I’ve rebuilt the entire front end from the frame out and changed wheels and tires completely, there are brand new shocks on all four corners new trans mount and soon to have new motor mounts for good measure. Without mounting a camera to my chassis I don’t know what is causing this issue and it’s not consistent. I’ve heard of some transmissions causing this but they were in older Ford trucks. Any input is welcome and I’m always open for knowledge. Thanx in advance
