Will 2004 17" 6 lug take offs fit on a 96 Tahoe 6 lug?
jrsavoie
Recruit
Rural Clifton, Illinois
Will 2004 Tahoe 17" 6 lug take offs fit on a 96 Tahoe 6 lug?
Apparently I was given some bad info. either before or after I bought them.
I haven't tried them yet but I was just told they will not bolt up. I was previously told they would.
Also are the valve stems the same old same old? He pulled the valve stems.
Thanks
they should fit just fine...I'm assuming he pulled the valve stems for the TPS sensors (Tire Pressure Sensors). But any valve stem will work. You don't need the new Fandango sensors for your aged fine glass of wine
