ghost183
im the new guy for this week...
iv been told you guys are the doctors of the 6.5
so....
had waterin fuel light come on 2 days ago, drained the cloudy mix out and got P0251,
so....
this morning started as usual, thru out the day start/stopping, i noticed the cranking time was getting more and more, it usually starts instantly when hot, but now cranked a few times to start, went to work, 5 hours later, tried to start it, wouldnt start, had to hold the throttle about 1/3 to get it to start, after it starts, idles like normal but runs with severely reduced power
checked for water again, had a small amount, drained the CLOUDY MIXTURE again, check engine light was still on since yesterday, so i didnt think anything of it aside from the P0251 thats in there,
so.....
just got home, and now i have;
P0251 = INJECTION PUMP METERING CONTROL
P0370 = TIMING REFERANCE HIGH RES SIGNAL
anybody know whats going on?!?!?!?
this IP was dealer replaced under that 12yr/120k mile warrantee thing about 40k miles ago, i JUST did the lift pump test, and its working properly, checked for air.. none... so im led to believe its internal to the IP. is it trying to tell me it has water in it? or air? cloudy mixture?
please help!!!
is my IP failing? im planning on draining the system tomorrow and getting fresh fuel in there
so....
so....
so.....
please help!!!
