Detroit Dan
Within the last year I put in a steering lift block to compensate for the 6 inch lift. After I bought it somebody told me it was not the ideal way to correct it, and that the blocks are known for loosening up. I've checked it once or twice and found all the nuts on the new studs were still tight. Lately I've been experiencing some weird wiggling when I hit the brakes, and after changing a tierod, wheelbearings, and retightening the spring u-bolts, I was going to replace the calipers. Pulled into a parking spot at the parts store and turned the wheel to back up a little to straighten it out, when POP there goes the steering. Took a look and found 3 out of the 4 new studs holding the arm and the block to the top of the knuckle broke, and 1 of them looked like a fresh break.
Very thankful it broke where it did, and not on the highway that I had just exited, with 2 of my kids with me. So, any of you D60 experts got any ideas? Obviously my first thought is that they were overtightened or undertightened. I don't think I overtightened them, but who knows, they had to have broken for a reason. They are a pretty beefy stud and I tightened them by hand, not with an impact. Another thought would be leverage, but even though I lifted it I haven't got real big rubber on it, they're only 235/85/16 measuring about 32" tall. I don't plow with it, heck I barely even drive it, this truck might have 3000 miles on it since I got it and put it on the road.
This is just another issue I've had in a very short time with my first D60. My whole life I've heard and read about how great they are, but all I've had is one problem after another. Dana 44s I used to put axleshaft u-joints in every so often, and balljoints now and again, but at least I got to drive them and use them. I plowed and ran 35 or 36 inch tires on my 44s without a bit of trouble. As far as problems go, the toughest front axle I ever owned was the IFS in my 97 3500. I beat the hell out of that thing with oversized mud tires and a 950lb snowplow for ten years, only real trouble was the wheelbearing hub assemblies didn't like the weight of the plow and the diesel and they would fail every couple of years. Still better than this POS. Everyone says IFS is weak and unreliable, well if I could trade my Dana 60 for an IFS out of a 90s 3500 I'd do it in a second.
So tomorrows project is to pull it off and see if I can get the broken studs out. Broke off flush, so it might not be fun. At least they haven't been in there for 30 years. Then I'll consider if I want to just replace the studs, or find a dropped steering arm or draglink to use instead.
