I have been considering a muffler. 4" variety. I was wondering if anyone knows a good muffler to use on a 6.5 for rumble reduction, but retaining the straight-pipe whistle. If not, I'll be leaving it straight-piped 'cause I am a whistle junkie!
SS Diesel sells a "Quiet" straight thru muffler....
i got a dynomax bullet muffler. havent installed it yet but its a very high flowing design and only cuts out about 2-4 dba of sound from a strait pipe. so im betting it will have whistle
The SSD quiet muffler is not straight thru, its baffled. I have a car chemistry Equalizer muffler that I am going to install soon. Its a compact 4" straight thru, but chambered, which should cut resonance significantly. They also customize inlet/outlet size and location. Dont know if results will be good for turbo or not.
If you have a Cat, gutting it and putting straight pipe with holes punched in it through the Cat might do the trick.
