Where to find a AC hose
bshull
Buhler, KS
I am looking for a compressor hose assembly for my 95 burb with rear air. The part has been discontinued :(. This is the hose that collects the freon return from the rear coil and receiver dryer, it also delivers the high pressure freon to the front coil.
Any leads on where to find discontinued parts?
Thanks
Brian
Brown and Brown Chevy in Mesa, AZ may have a set in stock. Do a dealer stock locate from your dealer. Otherwise AAPAK.com can rebuild your hoses or possibly get them.
I don't know how much good it will do you, but the ACDELCO part number is 15-30412 and the GM number is 15982000. Call MARKS AIR and see if he can find it for you. http://www.marksair.com/ Tell him the guy with the other DURAMAX suburban sent you. i know he deals with alot of aftermarket wholesalers and AC DELCO ditribution here in Tampa ALOT and has connections to find hard to find stuff. I can double check and see if I may still have my old one out in the shop, but I'm pretty sure I threw it out when I cleaned my shop.
Thanks for the help, I think I might of found the parts! The part numbers were the biggest help.
Thanks
Brian
Hello, I´m new in this forum and it has helped me a lot. I wrestling with the same promlem. I need the assy hose for my 4wd diesel sub with dual ac. Can You give me any advice from where I should ask the assy hose. I could make new rubbers for the assy but I don´t have any parts of it, so I need everything for it.
I bought a new set for my 95 Dually and got them from Macs Radiator in Portland Or
Most large radiator and Auto AC suppliers should have that stuff readily available.
Missy
If you have a hydraulic/racing shop type store in your area, they are equiped to rebuilt high pressure hoses like ac, power steering, brakes, etc.
I foundout how the hoses should go, Now I have to make them and machine a manifold to which connect the hose ends. Is there serviceports with threads available ?
