doughboy18718
Diesel Retard!
What are the normal operating levels for these?
The Temperature Gauge?
The Oil Pressure Gauge?
The Battery Gauge?
Thanks!
The Battery Gauge?
Thanks!
I think I will try that 6 guage mod to my alternater cable.
My 93 runs around 190 water temp, around 60 psi cold and 40 psi hot oil pressure, and around 14 volts
Speaking of guages......i see alot of people on here mention their intake air temp. Are you guys running a guage especially for it? and if so what make and model. I was interested in hooking one up to try some different intake configurations
If you don't mind a digital readout I'd recommend the ScanGaugeII. http://www.scangauge.com/ I watch my IAT on this as well as a lot of other info. It plugs into the DTC port and tells you what the PCM is seeing on most of the sensors (doesn't tell you MAP for some reason), can read and clear trouble codes, and has a somewhat flakey MPG meter in it. Lota gauges in one and for IAT you can see where your PCM starts its de-fueling when intake temp gets too hot.
Now of course this only works for the OBD2 rigs unfortunately, '96 and up, and they actually don't recommend it for our diesels. It works for most functions though and you need to specify a non-CAN cable.
I would recommend a 4 gauge mod.
-Rob![]()
