Acesneights1
That sums it up. Is it from the CPS or is it off the Alt ?
Do the 6.5 alts have a lug for the tach signal ? Where I'm going with this is wanting to hook a tach up to my 6.2. was thinking about ways to do it. Don't really wanna mess with magnets on the balancer. I may go with teh ESS OP drive but not sure how to wire it to say an Autometer tach.
The 6.5 diesel tach is run off of the stator output terminal in the voltage regulator. It simply reads the stator pulses like it would those of an ignition charge pulse since they are both similiar in wave length. GM didn't make the tach run off of the PCM in the 6.5's as there gasser tachs are driven directly off of the ignition charge circuit of the coil just like most all of your old style tachs were. The PCM couldn't produce this signal so they would have had to of made a tch generator to have run it or changed the tachometer, so they instead used the alternator stator output which produces a coil type wavelength and signal. Saved quite a bit of money on there part actually and provides a decent tach when you have the right pulley on it.
Thanks TD. If anyone can do it he can.I'll see if I can get GMCTD to weigh in he built a special tach converter for use with the 6.2 alternator that lets any aftermarket tach to be used
