Where can I find good detailed instructions on how to change the door on the Tahoe?
jrsavoie
Recruit
Rural Clifton, Illinois
I found a pair of green front doors for the 1995 Tahoe.
The seller had stripped everything off the doors, so I have to put everything back.
is there a good tutorial on how to do this? What glue do I need?
Is there anybody close that wants a little side job?
I also have a couple of rust spots that need repaired.
The whole door right? you threw me off with the "glue" comment.
Just unplug electrical, knock out the pins and catch the door before it hits the ground.
I have to swap the whole door and each and every part that goes to the door. Everything was stripped off the doors when I bought them. Not sure what to use for glue on the weather stripping
All the stuff came with the doors. Not sure why he felt the need to strip them
Or is there any glue invololved?
Due to the weight this is a two person and floor jack job. Sub it out if you can. The door hold open spring requires a special tool to install.
