First I want to say that I'm excited to be a member here. I've heard very good things about the knowledge base The Truck Stop's members. So... thanks for having me! :thumbsup:
I am rebuilding a late model 1995 4L80E for the truck in my sig that has excessive end play in factory unit (.037) which is well outside the specified tolerance of .009 - .024. Gears are in great shape but I need to find the thrust washers and pins. It's a 4 pinion unit.
Will the rebuild kit for the TH400 planetary gears work? Thats the only kit i can find with the washers and pins.
My rebuild manual has both planets and hardware listed as the same part.
Thanks in advance for your help.
