TravelingMan0491
So back in the week of July 4, 2012 I installed a golden fuel WVO system. Works great but recentlyI've noticed that my fuel guage would hit the "Full" mark at around 75-80 miles whereas before I would see 125-130. What I did notice is that while I'm on my WVO system, the diesel guage overtime creeps lower and lower so this leads me to believe that my diesel fuel is not making it's way back to the diesel tank. I have since moved back to Hawaii under Marine Corps orders and while here in Hawaii, I do remember a few times where I have forgotten to purge the system of the WVO before parking for the night. Could I have clogged up some of the return lines that go from injector to injector or maybe even the main return line that goes back to the diesel tank? I also noticed that rockauto doesn't carry the front feed/return fuel lines that are ahead of the lift pump unless they are called something else. Where is a good source or should I just go straight up rubber lines and cut the metal hose on the old front return line? I also do not notice any fuel puddles under the truck but not sure if it happens while driving.
Truck is a 94 Chevy K2500 extended cab 4x4
Thanks everyone!
Thanks everyone!
