ok, question for the efi gurus. I have a tune I tried running at the track. it seems to be a terminal work in progress... anyway. when i'm staging I logged engine torque reference and from about 55% throttle position all the way to 100% throttle position the torque gets to 523 ft lbs and roughly 1750 rpms ( wont go higher) and wont go any higher. I cant figure out where the truck is referencing from that would limit this. what tables would affect torque limits that I might be missing
B1124 disabled
B1125 disabled
B1126 disabled
B1130 disabled
I have B1115 and B1116 modified i'm just kind of stuck something is limiting the truck but I dont know what. if I add a butt load of PW in the main injection I have had the problem remedied but I couldnt control the power when staging , went from controlled to of the hook with just a tap of the throttle. my other problem is when its hot out 80s or better the truck bogs out of the hole and thick smoke once the brake is released then after it gets rolling she takes off like a rocket and smoke clears.
anyone have any thoughts.
B1124 disabled
B1125 disabled
B1126 disabled
B1130 disabled
