GM Guy
Manual Trans. 2WD Enthusiast
Hey all,
I used the search function, and all I found was someones personal reading, no posts telling what the vac level SHOULD be. the one member was getting like 25 inches.
So, I ask you folks, what should the vac level be? This is measured in inches, as in inches on the water column, correct? I got the proper Kent Moore guage, so I am sure that is what it reads. will an idle reading be good enough, or do I need to take it to a certain RPM?
also, is this reading supposed to be the same from 94-00, 1/2 ton to 1.5 ton, or is there differences with EGR equipped trucks? The truck in question that i am working on is the 1995 GMC C2500HD.
also, where should the reading be taken? at the pump I assume? If the pump checks out, I assume the reading should be the same at the solenoid and the turbo?
I will likely have to buy a new set of vac lines, but otherwise I think the rest of the system checks out, just gotta make sure.
It will hold boost if you get into it before the hill, but once on the hill it generally wont clamp shut and make boost, that is why I am checking it out in the first place.
thanks!
thanks!
