Thought we were done bleeding the system. Key on and have the red brake warning light.
Have very little fluid going out of the rear bleeders and the red warning light is on. Pedal will go to the floor when the engine is on. Plenty of fluid on the front bleeders. Did bleed the lines at the ABS unit.
Just more bleeding with a focus on the rears?
I had rolled it out of the garage to hose all the oil from the PS pump failure off. In doing so and NOT trusting the main brakes I had my foot on the parking brake.
Two clicks it was down turned the light on. :dunce:
Anyway bleeding lines at the ABS unit first did the job followed by all 4 corners.
