VW_Lupo_TD
Active Member
can someone SHOW or tell me exact location of fuel IP shutdown solenoid wire ?
just changed the fuel filter after it would not drain the fuel from filter housing. i turned open the air bleed valve too fast and it died on me. there was no fuel coming from drain (T-handle open).
after i could not get it started again, i took out the old filter and soaked up the old fuel with paper towels and cleaned out the fuel filter housing as good as i could. the little screen is still there.
put the new filter in and closed everything back up.
do not know where to
" Disconnect the fuel IP shutdown solenoid wire " to bleed the air from the manager/ filter housing, as i never had to do that before. but now i am afraid there is too much air and it cannot handle it.
running out of battery power, please help.
thanks in advance for your replies.
