What all would have to be done to install a hummer engine in my 98 Suburban?
I'm not certain but the Hummer pan may have to be replaced with one from a truck.
IIRC the heads are the same as the van heads and have diff angle on the intake so you'd have to mod the intake to mate up
If it's a non turbo N/A engine it will be the same as a truck(without coated pistons and some came without piston squirters), if it's a turbo engine then yes the heads will be different and the galley plug for the turbo oil line won't be there.
