Chief915
915A Maint Tech
So, back before my head gasket blew a couple months ago, my cruise worked just fine. Then the head gasket blew and I replaced the engine. After the engine swap, the cruise didn't work at all. It stayed that way, not working at all, for about 45 days or so of everyday driving until yesterday. Beginning yesterday, the cruise comes and goes all by itself.
The cruise switch can be off and I don't try to set the cruise or even touch the turn signal lever. When I am cruising along and let off the throttle, the engine stays steady like the cruise is on. It doesn't maintain speed, it slowly drops 1 or 2 mph every few seconds and touching the brake pedal will kick it down to idle just like the normal cruise control was working. The cruise will not come back on again until I acclerate again. After accelerating, again without ever touching the cruise switches, I can take my foot off the pedal and it will do the same thing again.
It doesn't rev up or act like it's going to run away or anything, just acts as if the cruise is set. I flicked the cruise switch on and off, wiggled the turn signal around, etc and it still does the same wheter the cruise switch is in the on or off position.
My grounds are good and clean, double checked that. I have 2/0 ground cables, one to the engine and the other to the frame. The grounds on the back of the intake are clean and tight and has a ground wire going from that stud down to the frame by the down pipe. Other than the cruise thing, everything seems normal. No check engine lights, stalling, hard starts, fish biting, etc.
Any ideas?
Any ideas?
