matuva
Tropical 6.5er
Something weird happened to a 1998 K1500.
The ECM was shot. As we had no 1998 ECM as spare (test with the ECM from another 1998, but could not left it on the truck) we tried a 1996 one... and she fired and runs fine & strong.
Security light stays ON, and we don't have glow cycle indication. Other then that, the truck run fine and strong.
It did run several weeks like that. Then, we changed injectors, BOSCH India. We added a Turbo Master.
Now the truck still start & run fine, but she can go beyond 87-90 MPH. Stays stuck at this limit, same as if there is a top speed limiter engaged :???: :???:
I don't think new injectors and Turbo master can do that? We adjusted the spring loose (2.5") as recommended for stock ECM, then tight (2") like if it is for an upgraded ECM, no change...
Any opinion?
Any opinion?
