Lazydog
Recruit
Title says it all. What is the weight limit on the factory install hitch? What can i look at towing safely with a factory setup and break controller?
I've towed over 10K several times with mine. Almost every weekend last year. Were the people having problems also those that use them in pulling competitions?
Careful doing that, you'll have the tail wagging the dog.I have pulled 16k w/ very little tongue weight, and the factory hitch has held fine, but i have had dreams about it coming off and having to stop it w/ the tailgate or something, and now those are going to be worse. What is the best one to upgrade to? What about a Brute II bumper/hitch, how good are they?
From what you said in this thread, it seemed like you were saying there was not much tongue weight. Like it appears here in this post as well. In another thread you said that it was a water tank trailer. If it's not a homebrew I'm sure it's designed properly. You should have 10-15% of the weight on the tongue. So if it's 16k, then you should have about 1600-2400lbs of tongue weight.Well, there is weight there, just not much, for 16k of water
