mgray
My batteries have been on the fritz for the last month or so(actually have my red tops, just need to get around to installing them), and my morning starts are borderline, sometimes requiring my 800amp booster pack. But usually it's just a few more seconds of slow crank needed to start. When my batteries are able to start me, it's after some slow cranking, and my usual small puff of blue smoke is now turned into a big puff of blue smoke and a few seconds of "soft" idle.
Anyways, I've noticed my oil level has been dropping a lot faster then normal, so I assume that bigger cloud of blue smoke I'm getting at start up is me burning more oil.
But the weird thing is, if I have a normal start(with strong batteries), that big puff of blue smoke is now reduced to the usual small puff of blue smoke, and my oil consumption isn't as bad.
So what I don't understand is how slow cranking can increase oil burn at start up? Is it just valve seals or is there something else I should be thinking about or inspecting?
Thanks for any ideas
