WaterPump backing plate
TomMac95
The (steel) mounting plate for my water pump is corroded so that the Mating Surface beneath the gasket is now about 1/8" rather than 1/4"-5/16" as originally fitted (in one area where salt residue sits on the timing-cover "shoulder").
I'm considering procuring a New-or-Used part with less rust.
I'm guessing the only source would be Dealer-or-Boneyard.
Does anyone know of any aftermarket availability??
Thanks , just checking
-T m
I installed 2002MY heads (with larger cooling passages) in 2003; the current project is limited to (I) new Timing Set {chain rather than gears--i'd Love gears , but no budget now} , (II) new HO water pump and Dual T-stat upgrade {i got a Kennedy kit without the fan/clutch since i mostly run light , am broke , and can do the fan stuff later without messing with the timing cover} , (III) new FIPump {DOA FIP was proximate cause of the maintenance task/upgrade}.
My stock exhaust (which was installed new 30kMi ago Before i learned that the restriction was a potential cooling problem) is another candidate for upgrading , but i'm not presently 'looking for trouble' !
Thanks for your response/suggestion.
Does the Heath kit include a coolant pump backing plate ??
Thanks ,
- T m
