cub124
Half Moon Detroit #1
So I figured I should share my water to air set up and I am also pondering a new turbo so I will list some of the specs of the turbos I am interested in and interested in but I may need some help filling in some missing specs. I'd also like to compare specs with the gm-8 so there is a good baseline turbo in there. I'm currently running the He351Ve.
First off my WTA from frozen boost. It was a reasonable price but at the time of install I didn't notice a huge increase in power or lower egts, probably because I had the boost set low. Or because there could still be air in the top of the inter cooler, so I may have to flip it 90* to make sure it stays full of antifreeze.
Now for the turbos
Schwitzer S2EGL069 (S2E, 103-2085)
Caterpillar 3116 170,185 HP, Various applications (Bus, Semi, GMC TopKick)
Compressor
Inducer: 57.5mm
Exducer: 76.2mm
57 trim
12 blades
0.60A/R
4" mouth, 2" outlet
Turbine
Inducer: 69.75mm
Exducer: 60.5mm
10 blades
0.70A/R
T3 flange w/split ports, 4" v-band outlet
Holset HE351Ve- 2007.5+ Dodge 6.7L Cummins
Compressor
Inducer: 60mm
Exducer: 86mm
14 blades
A/R:___
Turbine
Inducer: 70mm
Exducer: 60mm
12 blades
A/R___-1.0
(I think its 0.4-1.0)
Total weight 47lbs
Gm-8
Compressor
Inducer:
Exducer:
Trim:
blades:
A/R:
Turbine
Inducer:
Exducer:
blades:
A/R:
Hx35
Compressor
Inducer:
Exducer:
Trim:
blades:
A/R:
Turbine
Inducer:
Exducer:
blades:
A/R:
Hx40
Compressor
Inducer:
Exducer:
Trim:
blades:
A/R:
Turbine
Inducer:
Exducer:
blades:
A/R:
I know the hx35 & 40 have different housings and compressor wheels to choose from so I'll need to know the specs for the assortment of housings and wheels.
Now for the turbos
Compressor
Inducer: 57.5mm
Exducer: 76.2mm
57 trim
12 blades
0.60A/R
4" mouth, 2" outlet
Turbine
Inducer: 69.75mm
Exducer: 60.5mm
10 blades
0.70A/R
Compressor
Inducer: 60mm
Exducer: 86mm
14 blades
A/R:___
Turbine
Inducer: 70mm
Exducer: 60mm
12 blades
A/R___-1.0
Total weight 47lbs
Gm-8
Compressor
Inducer:
Exducer:
Trim:
blades:
A/R:
Turbine
Inducer:
Exducer:
blades:
A/R:
Hx35
Compressor
Inducer:
Exducer:
Trim:
blades:
A/R:
Turbine
Inducer:
Exducer:
blades:
A/R:
Hx40
Compressor
Inducer:
Exducer:
Trim:
blades:
A/R:
Turbine
Inducer:
Exducer:
blades:
A/R:
