water pump replacment
hotrod0872
Hernando, MS
do you have to remove the timing cover to replace waterpump?
got upgraded pump and dual tsat crossover,dmax 9blade metal fan and clutch i need to put on this weekend!
thanks for the help!!
Yes. It's no big deal but most WP's do not come with the gasket so buy it. You are not removing the entire timgin cover, just a plate on the upper half that will come off with the water pump as a few of the bolts for the WP go in from the backside of it.
Be sure to clean that radiator, and the AC condensor needs it badly too! Holy Moses that rig of yours is going to fly!
Once you have the pump off and the back plate removed and clean, be sure to use a little BLUE loctite on the bolts that go through the plate and into the pump.
If one of the inner bolts falls out and drops into the timing chain/gears its UGLY
Use either silicone or Hightack on the threads of any bolts that go through the front of the block into water.
Good luck
Missy
thanks for the info!got it all done in less than 2hrs not a bad job at all!
even moved pump and ran tdco learn and got -1.81
it runs like a beast now!:D
Good luck
Missy
That is a good idea..wish I would have thought of it when I did mine...:eek:
