Chief915
915A Maint Tech
I have a "normal" or "low output" water pump on my 94 suburban right now. I have a HO water pump sitting on a shelf waiting to get put on.
Question..... Will the new HO pump bolt up to the old water pump backing plate?
I seem to remember a Hummer at work with a "low output" water pump that had gone bad.... we got a HO pump for it, but some of the bolts wouldn't line up with the holes in the backing plate.....
Everything I read on here, or at least how I interpret it, says the HO pump is a direct replacement for the low output version.... with no mention of changing the backing plate. I just wanted to ask before I tear it apart and find out the hard way.
