Woody35
Active Member
So im pouring in the coolant after a 3 week injector, glowplug, pmd relocation, and oil cooler line job and it starts leaking under the truck. look under the truck and there is a small pinhole on the bellhousing that is pouring out coolant.
i then checked the tranny dipdtick and of course its all the way filled with coolant. well i figured out that the tranny cooler goes through the radiator to act like an air to water intercooler for the tranny fluid. i figure somehow the lines broke and coolant ran down into the tranny.
drained the tranny fluid/coolant and decided to look at it tommorrow. so you guys think i need new tranny cooler lines and cooler. any suggestions.
i guess the only good news to come out of this thouh is that the magnet had very little metal shavings so the transmission was not abused.
