Jess_sr
If I unplug the vacuum hose to the Wastegate Actuator and apply vacuum up to 28" from a hand pump shouldn't I see the shaft move into the actuator?
When the engine's shut off, the actuator is already moved to it's limit in the direction the actuator's internal spring pushes it - wastegate closed. Pulling vacuum can't move it any further in that direction. If it holds the vacuum, you know the diaphragm isn't leaking.
With the engine off, to understand the action (with less intimate personal involvement):h,) push the actuator rod towards the cab (overcoming the internal spring), then apply vacuum & it will pull the rod back - closing the wastegate.
The OEM vac/solenoid system varies the duty cycle of the boost solenoid, to vary the vac/actuator force pulling the wastegate closed. So when a vac line or pump fails, there's not enough force to hold the 'gate shut & low/no boost.
Thanks for the info guys.:thumbsup:
And no I'm not putting my mouth on the actuatoruke
:h
Not the actuator, the vacuum line plug to the wastegate solenoid. Unplug it and stand over the actuator itself and alternately blow and suck on it and you should see the actuator move.
