millsroger
Have a new to me 94 Silverado and the center HVAC vents had a problem, one loose, other would not move.
Took the panel out, unsnaps from the bottom, found the frame around the vents warped and the ends of the vents also warped. Caused one of the vents to pop out of position and one of the springs to bind up the other. Thankfully both springs were still there.
A good DIY fix:
Go to DQ and get a blizzard or milkshake--enjoy but keep the straw.
While enjoying, use a 1/1/6" drill by hand and drill the center of the outer pins 1/8"
The pins are the ones away from the adjuster knob.
Cut a couple of inches from the straw and cut it lengthwise.
It collapses on itself and will slip on the vent pin.
While on the pin, wrap it with scotch tape.
Cut the taped straw half way up the tape and then at the top of the tape.
Put the second piece on the pin for the other vent.
Mix up some JB weld, (liquid steel type).
Add a glop of JB in each straw about 1/8" to 3/16" deep, let cure overnite.
Put a 1/4" id washer on each extended pin.
Insert the vents, outside pin first and wiggle them down and in.
They will now be snug in the frame.
Re-install the springs----done.
Mine work perfectly now.
A good DIY fix:
