This will be the bracket I offer for the Suburbans. It is different than the trucks in length and hardware used.
Anyway here it is with the Walbro Pump and Wix 30 micron fuel filter. The base excepts 1-14 thead filters, so the racor with clear bowl type filter will work with this mount also.
At this time I don't offer the racor because the cost for just the element is about what the Wix filter and mount cost is. Just letting you know you can use raycor if you want.
Also, the pump base/inlet can be clocked 360*. In the picture below if I were plumbing it in I would turn it 90* facing rear to give a straight shot to the filter.
