ak diesel driver
6.5 driver
Hey will this work on my 99?
http://www.ebay.com/itm/30211222432...d5cc36acd27&bu=43183037829&cp=1&sojTags=bu=bu
Your buffer has two (2) sets of jumpered terminals that are opposed do like I did and install dip switches on them whatever the first set jumpers are the next set is opposite example 1234567 7654321 at very least you an just solder the terminals to match your ratio but dips make fine tuning easy.Hey will this work on my 99?
Heres the method of just soldering in solid jumpers. http://tbichips.com/?page_id=504
Radio shack can get you an 8 position dip switch, and you can just not use/cut off 2 on the end, then solder them in. Or do a search on google for "7 position 14 pin dip switch" and you can get them that way.
I had cut mine.Heres the method of just soldering in solid jumpers. http://tbichips.com/?page_id=504
I know many have used the radio shack ones, and its the ones the tbichip site used to reccomend.You make it sound like all dip switches are the same. I know for a fact they come in different pin widths etc.
My wife does enough of that at home.I'm surprised that nobody has made a comment about what a bunch of dip switches you all are! LOLWhere's @Burning oil when you need a Leroy comment?
Except for groceries, I don't go shopping with her. And when it comes to the groceries, she doesn't question me since I do the cooking(I would be a MUCH slimmer man if she did the cooking).Just at home? What about when out shopping?
Quit using southern cookbooks.
Ingredients: butter, butter milk, butter fat, salt, rendered butter, bread. Mix all ingredients except bread, then spread on bread. Eat to curb appetite between dinner and supper.
Yeah, why am I in the 250-260 weight class again? Haha.
You forgot cheese. You haven't had grits until you've had them swimming in butter, then enough real cheddar added to block an artery. You know they're good when they stick to the roof of your mouth.Don't forget the lard - everything must be fried in lard: Your eggs, your bacon, your sausage, your potatoes! And grits! You can't forget the grits! Grits with lots of salt on them and a big ol' dollop of butter melting over the top off them. Oh hell, a REAL delicacy, grits fried in lard, with lots of salt and pepper on them and that big ol' dollop of butter melting over them!
