Acesneights1
Last weekends trip with new Heath Tune and TM is now making my egts very very high. It I down shift to 3rd climbing a grade the boost hits about 15 and the egts run right up to 1300+. WTF ?? I knew I should have just fixed the vac pump. This is exactly what my Tahoe did after installing a TM.
FYI:
IP replaced last year(PO), Reman injs(accurate Diesel), remote PMD, New fuel lines. Hollowed out kitty with 4inch ex cut into it. Flowmaster downpipe abd crossover and NO EXH LEAKS(Pulled the friggin head to fix it.)
TDCO -1.50
The exact same thing happened to my Tahoe. It towed fine with no real temp problems until I put that damn TM on. I seriously think it's causing too much backpressure. what else could it be ?
I have an Autometer Pro series Pyro drilled right into the ex manifold under the turbo so the numbers are right.
FYI:
TDCO -1.50
