Valve covers are leaking. While my covers are off is there anything I should look for? I will be
Upgrade to roller rockers from Leroy? :)
Let me know if you manage to re-use the covers as the local shop has gotten in the habit of replacing them as they do not come off easily . . .
The previous 2 vehicles I reused the covers with no problem.
Roller rockers are to much for a 1995 with 320,000 miles and that we plan to give to my grand daughter, Unless I find something newer for her.
But what about nylon rocker arm keepers?
Where is the best place to buy them? Anything else along those lines?
If you want to remove the rocker arms to check for bad wear points on them and on pushrods. Just be sure to put everything back in correct direction and location. That many miles on engine it may not be worth it to mess with anything beyond the buttons.
Idk if Leroy sales them or maybe unique diesel? I used to get them at dealership.
Rock Auto and use the discount code on here. IMO just buttons alone are not worth vendors time, but, what do I know.
Leaking valve covers are easy to get off as the silicone has failed.
